Deploy MSI file?
Deploy MSI file?
I was wondering if anyone has created or knows of an MSI file for the install. We would like to deploy this to a lot of PC's via group policy. Unless there is an easier way to install on a lot of machines?
Thanks
Thanks
Re: Deploy MSI file?
Installation isn't really necessary - all you need is the files unzipped into a folder and a link to the Audacity.exe file.
I have tried to save files on the server and got each client to run the application but it says another instance of the program is running. Any more ideas anyone?
Works fine when one client is running the program.
Thanks
Thanks
Audacity needs to run locally (on the client, not on the server). The Audacity program folder needs to be copied to each computer on which it is to run. You then just need a link or shortcut on the client computers for launching the application.
- Quality Assurance
There is not really enough "demand" for an MSI installer at present but there is another solution here to automatically install Audacity on multiple computers:
http://wiki.audacityteam.org/wiki/Group ... stallation .
Reason: updated URL
Reason: updated URL
Yes, you can download a msi-package of Audacity 1.2.6 from this page:
http://www.inprose.com/package-repository.html
- Quality Assurance
Thanks. Is that your site/installer or you just found it? Installing for the user only into their Documents and Settings folder is a bit odd. Isn't this normally handled in the Registry and installation is to the usual "Program Files" folder?mon wrote:Yes, you can download a msi-package of Audacity 1.2.6 from this page:
Yes, my site and "my" installer. The per-user behaviour is by design in Windows Installer XML toolset (but I can change it in the installer). Default per-user behaviour in Wise Package Studio is "Program Files" and registry settings and shortcuts in profile. I think the behaviour of my Audacity installer is recommended by Microsoft (in Vista the target folder is %userprofile%appdatalocalappsAudacity).Gale Andrews wrote: Thanks. Is that your site/installer or you just found it? Installing for the user only into their Documents and Settings folder is a bit odd. Isn't this normally handled in the Registry and installation is to the usual "Program Files" folder?
Personally I always use per-machine in large scale deployments and per-machine is default in this installer.
I will make a new installer for the next stable Audacity release
- Quality Assurance
Thanks for your efforts. This is nonetheless the first MSI installer I've come across that doesn't install per-user into Program Files. Anyway, we'll note your link if anyone asks us. By the way, Audacity 1.4 (the next stable version) does not use the Registry for storing its preferences and settings - these are in an "audacity.cfg" file at:
Documents and Settings<user name>Application DataAudacity
There could be a disadvantage for novice users if that file is too close to the Audacity executable.
