audacity 1.2
audacity 1.2
Permanent link to this post Posted by merrill noble » Thu Feb 16, 2012 10:24 am
Please can someone help I am a first time user and the problem I am having is that everytime I go into effects the programm shuts down :?
merrill noble
Re: audacity 1.2
Permanent link to this post Posted by steve » Thu Feb 16, 2012 11:14 am
This is a typical problem of using the (very old) 1.2.x version of Audacity on a modern computer.
Try upgrading to Audacity 1.3.14 (you can get it here: http://audacityteam.org/download/ )
Re: audacity 1.2
Permanent link to this post Posted by merrill noble » Thu Feb 23, 2012 2:30 pm
I am not sure if it is me being an idiot but I cant seem to get the 1.3 to download, do I have to uninstall the 1.2 first perhaps. Please help.
merrill noble
Re: audacity 1.2
Permanent link to this post Posted by steve » Thu Feb 23, 2012 2:54 pm
You don't need to uninstall Audacity 1.2 before downloading Audacity 1.3.14, though it can help to avoid "file association" issues if you uninstall Audacity 1.2 before installing Audacity 1.3.14.
If you're using Windows 2000, XP, Vista or Windows 7, go to this page: http://audacityteam.org/download/beta_windows
look for where it says:
Recommended Download
Windows 2000/XP/Vista/7: Audacity 1.3.14 installer (.exe file, 18.4 MB) - The latest version of the free Audacity audio editor, including help files. See further information about Windows 7 and Vista.
and click on the underlined link that says:
When it has downloaded, double click on the downloaded file to run the installer.
On Windows Vista or later you may be prompted to enter an administrator password during the installation.
Re: audacity 1.2
Permanent link to this post Posted by merrill noble » Thu Feb 23, 2012 3:19 pm
every time it gets to 99% it stops and says a time out what does that mean, its driving me crazy I amso near and yet so far
merrill noble
Re: audacity 1.2
Permanent link to this post Posted by steve » Thu Feb 23, 2012 3:33 pm
I've just tried it and it downloaded fine.
Alternatively you could try this link: http://audacity.googlecode.com/files/au ... 2.0rc2.exe (direct link)
This is a slightly newer version of Audacity. It is the "release candidate" for Audacity 2.0.
The main difference between this version and the 1.3.14 version is that this will install over the top of Audacity 1.2.6, so no need to uninstall your old version first. It also contains a few bug fixes.
Re: audacity 1.2
Permanent link to this post Posted by merrill noble » Thu Feb 23, 2012 3:56 pm
Thank you thank you I have manged to install the 1.3 now before i start recording can you tell me which is the best volumn on the mic I should use and to get a real smashing recording what are the best settings to us
merrill noble
Re: audacity 1.2
Permanent link to this post Posted by steve » Thu Feb 23, 2012 4:29 pm
merrill noble wrote:which is the best volumn on the mic I should use
See here: http://manual.audacityteam.org/man/FAQ:Recording#olevel
You'll probably find it useful to have a glance through the other FAQ also http://manual.audacityteam.org/man/FAQ
This tutorial may be useful: http://manual.audacityteam.org/man/Tuto ... _Recording
Now that we have hopefully sorted out your initial problem, if you have further questions start a new topic in the Windows > Audacity 1.3.x part of the forum. (one question per topic makes the topics much easier to follow ;) )
Return to Windows
Who is online
Users browsing this forum: No registered users and 10 guests
