Fk-Trampe wrote:There's about 51 hours record time left on the D drive, the C drive only has windows installed,
By default, Audacity stores its data in a temporary folder on the C: drive, so free space on the C: drive is important.
Once you have "Saved" the project, Audacity will use the project data folder instead, so if you want to be sure that Audacity is writing to the D: drive, save the project
before you start recording.
Just because he computer is not connected to the internet will not stop Windows from trying to update . To stop Windows from trying, you need to disable automatic updates in the control panel. Also worth using the Task Manager to check what else is running. If your machine came with Windows pre-installed, many manufacturers have a nasty habit of installing all sorts of rubbish for you.
It is not generally recommended to record onto an external hard drive as data bottlenecks can occur - I'm hoping your D: drive is an internal drive.
Even after 6 months, it's worth checking if defragmentation is necessary. Windows XP defrag utility allows you to "analyse" the disks and tells you if defragmenting is required.
