Ann
Question Marks
Question Marks
I too have question marks instead of words on my tool bar and drop down menus consist of ??? also just like poppy1
Ann
Ann
Re: Question Marks
What language is selected in Audacity Preferences (Edit > Preferences > Interface)
Re: Question Marks
You can't open anything on the drop down menu's therefore you cannot go through preferences as once you click on the ???? it shuts down
Re: Question Marks
Try resetting the preferences as described in this article: http://audacityteam.org/wiki/index.php? ... references
If you are not confident about editing the Windows Registry, you may decide to take the easier option and install Audacity 1.3.5 (1.3.x uses a file instead of the registry for storing the preferences)
Re: Question Marks
Thank you I have reset the preferences and this seems to have worked thank you for your help
