Can't import file (.wav) in audacity *URGENT*
ceneiqe
Post by ceneiqe » Mon Sep 15, 2008 12:21 pm
I went into :
http://audacityteam.org/help/faq?s=edit ... ove-vocals
and then i followed the instructions but :
1. Audacity doesn't recog my file (.mp3)
2. i changed my format to .wav but still doesn't help.
What should i do ?
Re: Can't import file (.wav) in audacity *URGENT*
Post by steve » Mon Sep 15, 2008 4:23 pm
The problem is most likely that the file is not really an MP3 file, or a WAV file, but in some other format.
In Windows, you can right click on the file and select "Properties" then look in the "Advanced" properties to see what format the audio file is (also the number of audio channels, bit rate, etc.). If Windows does not say that it is a WAV, or and MP3, then it isn't.
If that's not the problem, then it may be that the file name is using invalid characters - if it has any unusual characters (or non-English characters) then try renaming it.
It may be worth me mentioning that "vocal removal" very frequently does not work with MP3 files because the MP3 compression messes with the stereo separation.
ceneiqe
Post by ceneiqe » Mon Sep 15, 2008 5:55 pm
stevethefiddle wrote:The problem is most likely that the file is not really an MP3 file, or a WAV file, but in some other format.
but it is .wav format.
i am running on windows vista. does it have any conflict with audacity ?
the name of file is in english.
Post by steve » Mon Sep 15, 2008 6:31 pm
ceneiqe wrote:but it is .wav format.
What sort of WAV? Could you post a screen shot of the Advanced Properties?
ceneiqe wrote:i am running on windows vista. does it have any conflict with audacity ?
Have you read this? http://audacityteam.org/wiki/index.php? ... s_Vista_OS
ceneiqe wrote:the name of file is in english.
What is it?
ceneiqe
Post by ceneiqe » Tue Sep 16, 2008 4:52 pm
I got it ! finally !
as suspected the mp3 file might be corrupted. so i downloaded the same song from another source (also mp3 format)
and it works !
but the voice is not 100% removed.
I try to use Effect > Amplify (in negative direction) but the vocal echo is still there.
any other effects i can try to remove more of the vocals ?
Thanks !
