Echo coming from turntable as I'm recording
mbowcock
Post by mbowcock » Sat Sep 06, 2008 11:46 pm
I'm new to Audacity and don't know all the buzzwords, but I need help. My first recording went really well and I was really excited about being able to record my LP into the computer. But when I tried it again with different LP I heard an echo when the record was playing, like the song was playing twice, with only a second or two delay.
What could be happening? Should I uninstall and reinstall Audacity? If I do will I have to reconfigure my computer again?
I'm running Windows Vista, if that makes a difference!
Re: Echo coming from turntable as I'm recording
Post by kozikowski » Sun Sep 07, 2008 12:17 am
<<<ike the song was playing twice, with only a second or two delay.>>>
It's possible to mess up the live sound monitoring on a Windows machine but still get a good recording. Did you get a good recording?
mbowcock
Post by mbowcock » Sun Sep 07, 2008 1:31 am
Actually, yes. I didn't record the whole song, just the first 30 or 45 seconds, but when I played it back it was alright.
Post by kozikowski » Sun Sep 07, 2008 5:37 am
You can dig in the Windows Sound Panels and turn off anything you're not using--like Mix Out, or What You Hear. Those can cause an echo.
Windows Control Panel
If you're in Vista, that's a whole different problem.
