Problem recording from USB Turntable
mike blackmun
Post by mike blackmun » Tue Sep 02, 2008 2:41 pm
Just purchased a Zennox USB Turntable that came complete with Audacity 1.2.6. Installed it yesterday and made a trial recording with no problem (can't remember what preferences were used, but I did not alter those that were preset). Switched computer on today, and get no output to the left and right channel indicators, nor to my external speakers. When I press the record button, get a series of regular clicks that builds up into negative feedback. Have switched USB ports, but to no avail. Am using Windows XP. I did notice from your FAQs that in the I/O preferences there should be a USB option, but this does not appear in my drop down menu. Any help would be greatly appreciated.
Regards
Mike B
Re: Problem recording from USB Turntable
Post by steve » Wed Sep 03, 2008 10:29 pm
mike blackmun wrote:I did notice from your FAQs that in the I/O preferences there should be a USB option, but this does not appear in my drop down menu
Are you looking in the right place?
"Edit > Preferences > Audio I/O"
waxcylinder
Post by waxcylinder » Sun Sep 07, 2008 3:46 pm
As Steve says - and you may also need to re-set your Windows sound output to target your PC's onboard soundcard too.
When you plug in a USB device like this it normally takes over both the sound input and sound output (useful if you are using an external soundcard - but not so good when using a USB TT with no speakers!). Also note that AUdacity hands complete control over the input Audio to the USB device and I would not expect to see options available in the input selector dropdown - nor should the Audacity input level slider work.
