changing the colors of the screen
masdefi
Post by masdefi » Mon Oct 17, 2011 12:11 pm
hi all,
is there any chance to customize the screen color (the default grey) on the version 1.2 or 1.3 ?
thanks
masdefi
Re: changing the colors of the screen
Post by Gale Andrews » Tue Oct 18, 2011 3:00 am
masdefi wrote: is there any chance to customize the screen color (the default grey) on the version 1.2 or 1.3 ?
What do you mean - the selected colour in the waveform or the background colour below the track?
The answer is basically no unless you are a programmer and want to modify Audacity, in which case build the latest Beta development source code:
http://audacityteam.org/community/developers#svn .
If you are not a programmer all you can do is go back to an old buggy Beta (1.3.8):
http://audacity.googlecode.com/files/au ... -1.3.8.exe
then try out the "Theming" feature:
http://manual.audacityteam.org/man/Theme_Preferences .
masdefi
Post by masdefi » Thu Oct 20, 2011 10:52 am
thank you very much,
but it seems to me a bit difficult.
I will let it as it is,
thanks for the help
masdefi :?
