KeyMs92
Post
by KeyMs92 » Tue Sep 20, 2011 6:41 pm
Hi,
I've been struggling for a few hours with these annoying sound pops from a BBC stream recording. I've tried every effect and trick I could think of but the result hasn't become 100% (or 99%) satisfying. It seems as if the sound pop doesn't really go along with the sound but is rather replacing it; I've had the best by results by just removing it and then either replace it with nothing, silence or a small repeat of the sound just before the pop. Still, it is quite noticeable.
I've added a short clip, so if anyone can give me some advice.. much appreciated!
- sound pop.wav
- (603.14 KiB) Downloaded 54 times
- Site Admin
Post
by steve » Tue Sep 20, 2011 9:25 pm
I presume you mean the weird "blip" just after 6.3 seconds?
It sounds like that was a glitch in the BBC stream. There's no automatic way that I know of to get rid of that, but if you cut out the bad bit, then make a short cross-fade between the parts either side then you can get a pretty good repair.
- Click on image to expand
- window000.png (45.17 KiB) Viewed 565 times
- sound-no-pop.flac
- After the repair
- (327.9 KiB) Downloaded 53 times
KeyMs92
Post
by KeyMs92 » Tue Sep 20, 2011 10:05 pm
Yes indeed, 'blip' is the better word for it.
Your advice was really useful! I've tried it and although still audible it'll probably go unnoticed for the unconscious-minded (which is the point). I'll stick with this solution for all the blips to come
