Recording Lag
riannaking
Recording Lag
Post by riannaking » Sun Sep 18, 2011 10:52 pm
When I go to record something, there is about a 1second lag/delay between when I play something to when I hear it on the program. Is there a way to calibrate the playback delay or a way to fix this problem?
Re: Recording Lag
Post by steve » Sun Sep 18, 2011 11:00 pm
What sort of microphone are you recording with?
Which version of Windows?
Which (exact) version of Audacity (look in "Help > About Audacity").
riannaking
Re: Recording Lag
Post by riannaking » Sun Sep 18, 2011 11:08 pm
I'm using a usb cable to connect from my computer the my piano. I have Audacity 1.2 and I don't know which version of windows but it's lower than Windows 7.
Re: Recording Lag
Post by steve » Sun Sep 18, 2011 11:16 pm
riannaking wrote:I don't know which version of windows but it's lower than Windows 7.
If you reboot your computer there should be a screen come up that says which version of Windows you are using. Alternatively, if you have a "My Computer" icon on your Desktop, right click on it and select "Properties".
riannaking wrote:I'm using a usb cable to connect from my computer the my piano.
Do you mean this sort of thing: http://www.alesis.com/guitarlinkplus
