Input source
Tdillon
Input source
Post by Tdillon » Tue Sep 13, 2011 3:17 pm
The input source on the mixer is grayed out. I can't seem to find a way to make it show so I can select mic, line in, etc
Can someone help me?
Thanks
Re: Input source
Post by kozikowski » Tue Sep 13, 2011 7:14 pm
When someone has system trouble like this with Audacity 1.2, we push you off immediately to Audacity 1.3.
Audacity 1.2 is very old and no longer supported,
patched, corrected, or updated. Audacity 1.2 can
be unstable on newer computers.
Download and install the latest Audacity 1.3 from here...
You can install both audacity 1.2 and Audacity 1.3 on
the same computer, but only use one at a time.
Audacity 1.2 will not open projects made on Audacity 1.3.
If you use MP3 or some of the more modern audio
compression formats, get Lame and FFMpeg software
from the same web site. Do not use older software
or software from other web sites, even though they
may have the same names.
