Hello people, I'd like to get some help with one matter:
I want to know what effect was used to turn this sound: http://www.mediafire.com/?ee00wyuckq2cw3w
into this one: http://www.mediafire.com/?l53mfv52azm7lo2
Yes, I'm pretty sure it's the same sample. I've tried with bass boost and low pass filter, but it leaves some sort of echo, due to the nature of the original sample.
As you can hear the modified sample sounds like a bass drum, like if you put a pillow between the speaker and your ear.
I hope you can help me, thanks in advance!
Which effect was used?
flowerzink
Re: Which effect was used?
Try playing with the Change Pitch, Change Speed and Change Tempo effects and lots of Equalization to make the spectrum similar.
There's a lot of weird distortions going one that are hard to identify, but have a metallic kind of sound similar to encoding an MP3 at too low a bit rate.
flowerzink
In short what I want to do is turn a door slam into a bass drum sound. To do that, I need to know how to make the sound smoother, not just filter the lower frequencies.
I hope I've made myself clear
Why not just download a bass drum sound? http://www.freesound.org/
- Quality Assurance
Or put bass drum on a track beneath the door slam and use the gain slider on the bass drum track to mix in just enough of the bass drum to make the slam more like a drum.steve wrote:Why not just download a bass drum sound? http://www.freesound.org/
