Hello,
I'm new to Audacity. I have several tracks that are all recorded in sequence as they should be however the last track recorded (titled Track 1) needs to be moved ahead of all the others. How do I shift tracks 2-5 over about a minute so that Track 1 will be the first to play in sequence?
Any help on this *hopefully* simple task is greatly appreciated!
Cas
Changing order of tracks
Re: Changing order of tracks
Use the Time Shift tool (double headed arrow <-> ) and slide the tracks left/right to where you want them.
I'd highly recommend that you upgrade to Audacity 1.3.13 unless you are using a pre-Windows XP operating system.
