support
Re: support
It should. If it's still running Win7, then the latest Audacity Beta, 1.3.13, should slide right in.
Do Not use Audacity 1.2.
That's a pretty simple, stripped-down computer, so you won't be mixing a massive symphony any time soon, but for simple recording and editing, it should be OK.
Re: support
Thanks for the info, any other suggestions re: using Audacity for recording ie. laying down track is most welcome...
Re: support
Say that again and use a lot more words.Audacity for recording ie. laying down track is most welcome...
"I want to connect my Logitech Desktop microphone to my Toshiba Satellite Windows 7 laptop and record my guitar and singing in Audacity 1.3.13."
If you make it too fuzzy and generic, we can't tell the direction you're going to keep you out of trouble.
Re: support
I'm new to this and I tend to type in shortcuts because of my job but I'm trying to learn thanks H.
Re: support
See the links at the top of the page:jtklives wrote:any other suggestions re: using Audacity for recording ie. laying down track is most welcome...
• Tips • Tutorials • Documentation
