Projects and Tracks
Graywolf
Projects and Tracks
Post by Graywolf » Sat Aug 27, 2011 10:21 pm
I have downloaded some audio books that have several individual tracks under the same title. Can anybody help me with putting them all in one folder under that title. I have looked in the help section but don't seem to be able to tie things all together. Or will I be stuck with having to listen to each track one at a time? I currently have as an example 12 tracks named Alexander the Great downlaoded individualy in my Music Folder named Audio Books and not in the Temp folder. Thank you for any help any of you can provide.
Re: Projects and Tracks
Post by Gale Andrews » Sat Aug 27, 2011 10:37 pm
Graywolf wrote:I have downloaded some audio books that have several individual tracks under the same title. Can anybody help me with putting them all in one folder under that title. I have looked in the help section but don't seem to be able to tie things all together. Or will I be stuck with having to listen to each track one at a time? I currently have as an example 12 tracks named Alexander the Great downlaoded individualy in my Music Folder named Audio Books and not in the Temp folder.
Have you looked at
http://audacityteam.org/help/faq?s=editing&i=join ?
If the audio books are in AAC format you will have to upgrade to Audacity Beta:
http://audacityteam.org/download/beta_windows
then install FFmpeg:
http://manual.audacityteam.org/man/FAQ: ... tallffmpeg
in order to import the tracks into Audacity.
If you are exporting to WAV after you joined the files together, note that there is a practical file size limit of 2 GB for the exported WAV.
If you are exporting to MP3, see:
http://audacityteam.org/help/faq?s=install&i=lame-mp3
Graywolf
Post by Graywolf » Sun Aug 28, 2011 8:18 pm
Gale, thank you so very much for pointing me in the right direction. It is working just fine.
