Hello.
I'm using version 1.2.6 along with an NAD PP 3i and a Thorens TT.
The left channel is very slightly lower than the right. Barely noticeable, but it is.
While recording I go to the "Effects" tab but everything is grayed out, unusable.
Any suggestions here?
Uneven recording levels
- Quality Assurance
Re: Uneven recording levels
Remove any loud clicks with Effect > Click Removal or other means, then use Effect > Normalize which will make the peak loudness of both stereo channels the same.sombunya wrote:I'm using version 1.2.6 along with an NAD PP 3i and a Thorens TT.
Audacity does not yet perform effects on live audio. Click the yellow Stop button, then select some track to apply an effect to. You probably want Edit > Select... > All. See:sombunya wrote:While recording I go to the "Effects" tab but everything is grayed out, unusable.
http://audacityteam.org/help/faq?s=edit ... u-disabled
I'll give it a try today.
Thanks much!
Thanks much!
