Can't Click Anywhere Except Plug-In Window, but I need to..
Manglehold
Post by Manglehold » Sat Jun 11, 2011 6:49 pm
I'm using a VST plug-in. To use one of the features of the plug-in, I need to be able to click on the main play button while the plug-in window is still open. But with Audacity, I can't click anything else while the plug-in window is open.
Is there any way to change this?
Re: Can't Click Anywhere Except Plug-In Window, but I need t
Post by Gale Andrews » Sun Jun 12, 2011 12:20 am
Manglehold wrote:I'm using a VST plug-in. To use one of the features of the plug-in, I need to be able to click on the main play button while the plug-in window is still open. But with Audacity, I can't click anything else while the plug-in window is open.
No. Audacity doesn't yet support real-time effects. That is why effect windows block other actions. You can preview the effects using the Preview button, but can't change the effect parameters and hear the result while the audio plays.
