New To Program And Needs Help
Tanner2007
Well hey im new here and to the program well to cut to the point im trying to edit the song Mozart - Carmina Burana O Fortuna there some parts that go loud then very soft low volume i want to make all the low volume parts same as rest of the song i tryed using that tool to change volume over time and also tryed apflying it but then i get loud static barley right when you hear it start to play again can anyone help me here?
Re: New To Program And Needs Help
Carmina Burana is by Carl Orff not Mozart.
Chris’s dynamic compressor is a plug in effect that will probably accomplish your task.
Read his pre-amble so that you understand what it does, then download it an put the .ny file in your Audacity plug-in folder. (It may require Audacity 1.3.x )
http://pdf23ds.net/dynamic-compressor/
Tanner2007
ether way still got it and ill try it out thanksstevethefiddle wrote:Carmina Burana is by Carl Orff not Mozart.
now how do i use it? lol
Most filters and plug-ins work by selecting some sound on the timeline and then selecting a filter (generally Effect > Something). The effect you selected will present a control panel where you set your desires. Then press OK.
Play the work. If you badly screw up, Edit > Undo.
Tanner2007
thank you now heres another questions how can i make the file size smaller while exporting into .mp3?
Some audio programs let you choose the compression amount at the point of export. Audacity doesn't do that. It sets the compression in Preferences > File Formats.
Remember MP3 is destructive. It gets the smaller file sizes by reducing musical quality. And it's permanent. You can't ever go back up to higher quality.
Tanner2007
Do you know a good program that can?
waxcylinder
Yes, Audacity 1.3.x the Beta version can (and so will the upcoming 1.4 release).Tanner2007 wrote:Do you know a good program that can?
On Export to Mp3 (or whatever) there is an Options button which lets you set parameters at the point of export.
<<< Do you know a good program that can?>>>
I don't know any program that can recover lost quality, good or otherwise. That's the down side of MP3 and the picture version of that, JPEG.
Audacity 1.3 lets you set compression at the export step. It won't reverse the damage, either.
