recording through M-Box
jhawk85
Post by jhawk85 » Fri Aug 08, 2008 2:19 pm
I have read other posts about this topic, but none solve the problem. I am running Audacity on Windows XP and I have downloaded WDW and still do not find the M-Box as an option on preference I/O options. I can hear Audacity through M-Box, but I cannot record. Is there a solution for this? M-Box does not come up as an option in the Windows control panel for recording either.
Thanks for any help.
Doug
Re: recording through M-Box
Post by steve » Wed Aug 13, 2008 11:55 pm
jhawk85 wrote:M-Box does not come up as an option in the Windows control panel for recording either.
You need to fix that first.
It sounds like you do not have the correct drivers available.
jhawk85 wrote:I have downloaded WDW
Do you mean WDM drivers?
They may be the wrong ones, or not installed correctly.
Until you have the correct Windows drivers installed, Audacity will not be able to communicate with the audio device. You can tell if the correct drivers installed correctly for the M-Box as it will then be available as an option in the Windows control panel for recording.
Sorry I can't help further - I don't have an M-Box.
