Hello,
I am using an audio interface to record guitar and vocals simultaneously.
IN audacity I have selected stereo recording.
Recording is not an issue. It is recording fine.
Problem is when I play back, my vocals is on the right speaker only and guitar in left speaker only.
Is there a way to mix them so that both sound in both the speakers when played back ?
Thanks in advance,
ngs
stereo recording - need info
billw58
Re: stereo recording - need info
From the Track drop-down menu http://manual.audacityteam.org/man/Track_Drop-Down_Menu select "Split Stereo Track". You will now have two separate tracks, but they're dedicated to Left and Right channels. In the Track drop-down menu in each of the new tracks, select "Mono".
-- Bill
PS: Are you really using Audacity 1.2? Note that the manual page I've linked to shows the 1.3.13 Track drop-down menu, although the one in 1.2 is similar.
-- Bill
Hi Bill,
Thanks a lot ! It worked just fine.
Yes I am still on 1.2.X. I will upgrade soon.
Thanks again,
ngs
Thanks again,
ngs
