Multiple track points in contiguous mix
ericmci
Post by ericmci » Mon May 09, 2011 11:58 pm
Hi I am using Audacity 1.2.6 on a windows 7 machine.
What I would like to do is take one long continuously mixed set of music and insert multiple track points
so that the listener may skip ahead to different track points in the mix But keep the whole thing
as one contiguous mp3 file.
Thanks in advance
-Eric
bgravato
Re: Multiple track points in contiguous mix
Post by bgravato » Tue May 10, 2011 12:26 am
ericmci wrote:Hi I am using Audacity 1.2.6 on a windows 7 machine.
You should stop there! The recommended version for windows 7 is 1.3.13.
Audacity 1.2.6 will be very unstable if it runs at all.
Audacity 1.2 is very old and no longer supported,
patched, corrected, or updated. Audacity 1.2 can
be unstable on newer computers.
Download and install the latest Audacity 1.3 from here...
If you use MP3 or some of the more modern audio
compression formats, get Lame and FFMpeg software
from the same web site. Do not use older software
or software from other web sites, even though they
may have the same names.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
bgravato
Post by bgravato » Tue May 10, 2011 12:28 am
Regarding your request... I don't know of any software or audio format that will allow you to do that. At least not with an mp3. And not one that will work with a standard music player...
