Change Recording to 32kbps to 149kbps??
tcr1016
Post by tcr1016 » Wed Apr 27, 2011 9:08 pm
I have audio that is to quiet, so how do I make it louder without ruining the audio speaking??
Thanks
Re: Change Recording to 32kbps to 149kbps??
Post by steve » Thu Apr 28, 2011 12:50 am
Option 1.
Export the amplified file as a WAV file
Option 2.
Find the MP3 settings in Preferences.
(Edit menu > Preferences)
Option 3.
Upgrade to Audacity 1.3.13.
In Audacity 1.3.13 you can set the MP3 rate in the Export dialogue screen by clicking the "Options" button.
Option 4.
Use "Replay Gain", or if you are wanting to play the file on an iPod, use "Sound Check" in iTunes.
