Recording with USB microphone
Hello. I've tried recording with a USB microphone, but when I try to record multiple tracks, I can't hear the current tracks as the new one is recording. Any advice?
Re: Recording with USB microphone
Do you mean that you can't hear the track that was recorded first, or that you can't hear what you are recording second?Tank_ wrote: I can't hear the current tracks as the new one is recording. Any advice
I can't hear what I recorded first when I hit record to add another track above it. If I use the laptop's in-built recording hardware this isn't an issue.
"Edit menu > Preferences > Audio I/O"
Ensure that:
1) The output device is set to your normal sound card and not to the USB device.
2) "Play other tracks while recording new one" is enabled.
Ensure that:
It works now. Thanks!
