I searched and couldn't seem to find an answer to this question...
I just got a Grace USB turntable and use Audacity 1.2.6 to record. I have had some sucess with "out-of-the-box settings, except for one issue (that was not my fault).
The mp3 file that I created after recording has a very low volume, so much so that I must turn my spearers all the way up when playing back. Not really a big deal, until the next song comes on VERY LOUD.
How can I up the output volume on my files.
Also, my first big oops. NEVER rename a directory while recording to it. Windows allows you to do it, but then everything being recorded gets "lost". Oh well, live and learn!
Thanks
Output Volume
waxcylinder
Re: Output Volume
Select the track or tracks in your Audacity Project and use Effect > Amplify - don't be tempted to tick the box that says "allow Clipping"
