Hey guys,
I seem to be getting a common problem but I cannot figure anyway to solve it.
In version 1.2 I get an error saying "The file you have selected is an Audacity Project Title" and in the 1.3 beta I get it suggesting importing it as a RAW file.
I have just retrieved it from a harddrive on another computer (where for some reason I deleted it and then emptied my recycle bin) and kept the worser versions of songs I have sung. I have the _data folder the .aup file and the .aup.bak file. Any help you can offer me would be greatly appreciated as I need this for school work... pretty much tomorrow.
Thanks in advance for any help,
Drew
P.S I also have a MP3 version (I didn't use lame) and a WAV version.
Unable to open project file
Re: Unable to open project file
You may be stuck with the WAV and MP3 versions. Once you mess with the structure of an Audacity Project, it's very difficult to return to normal -- particularly in Audacity 1.2.
A great many forum complaints start: "I tried to move an Audacity Project between computers......"
And then something really awful happened.
In general, if you have an AUP file and a _DATA folder of the same name, you should be able to put them both on the desktop, right-click the AUP file > Open With > Audacity. The show should open. If it doesn't, then it's damaged and that's probably the end of the story.
You can't drag and drop an Audacity Project file. Use "File menu > Open".Drew wrote:in the 1.3 beta I get it suggesting importing it as a RAW file.
