The bits at the top of the screen, like the input bar and the volume and recording levels bar are in different places than normal.
The volume level used to be on the left, now it's on the right.
What's happened?
How do I set it back?
Help! My interface has changed!
steelie1955
Re: Help! My interface has changed!
Which version of Audacity are you using? (Look in "Help menu > About Audacity")
Do you have Audacity "full screen" or as a smaller window? (the toolbars will shuffle around to fit the available space).
The Toolbar options are in the "View" menu. You can enable/disable options here and in Audacity 1.3 there is an option to "Reset" them back to their default positions.
Toolbars may also be dragged out of their normal potions or replaced back into their "docked" positions.
The arrangement of the toolbars is more flexible in Audacity 1.3 than in the old 1.2 version.
steelie1955
It's version 1.2.6
I think everything has changed because I have just installed a new flatscreen monitor, with a totally different resolution than the previous monitor.
I'll get used to the new layout
