USB Connection
jbowlin
USB Connection
Post by jbowlin » Thu Mar 24, 2011 9:12 pm
I want to record using a USB connection to desktop. Sometimes Audacity shows the USB option under "Edit" Preference, but most time not.
It shows the USB option for input under "Preference" it will recorder properly. Coult this be a USB cable or the cassette player TAPE2USBII, or problems with the USB connections on the computer. I have 3 USB connections, none seem to work.
Re: USB Connection
Post by steve » Fri Mar 25, 2011 9:10 am
USB audio devices must be connected to the computer and recognised by the operating system before you start Audacity.
jbowlin
Re: USB Connection
Post by jbowlin » Fri Mar 25, 2011 6:11 pm
Thanks Steve I tried that but did not work. I checked the USB ports on the the computer. The troubleshooting indicated they were all working properly. I will try a new USB cable from my cassette player and see if that makes a difference. On the occasions that it did work the USB Codex was an option under "Preferences" If you have any other suggestions, would appreciate.
jbowlin
Re: USB Connection
Post by jbowlin » Sat Mar 26, 2011 1:40 am
I finally got the USB connection to work after several time disconnecting the USB cable and reconnecting
