Help..Exported file will not let me open
superman76103
Post by superman76103 » Thu Mar 24, 2011 5:49 pm
i have windows seven. i used the stereo recording to record something from a dvd and it exported fine.. but when i did it with my friends cd he was in and i tried to export it . it has a little lock on it and wont let me do anything with it? any one know wat to do
Re: Help..Exported file will not let me open
Post by Gale Andrews » Sat Mar 26, 2011 10:39 pm
Do you mean your friend visited you, you recorded his/her CD and exported a WAV, and now the WAV is on your computer? Or did this happen on your friend's computer? If so, is that also a Windows computer? In what program do you see the lock icon? Do you have a screenshot of the lock you can upload here?
If you still have the project, try exporting it again to your Desktop or your MyMusic folder, which should not be locked.
