how can I create screenshot
Hello. We I work with some program - I always get error. But my stupid boss don't believe me!!!! I want to show screenshot to his, but I don't how can I do it? Help me please!!!
Re: how can I create screenshot
Press Print Screen SysRq, a button which should be located on the right side of your keyboard.
Then paste the image in Paint or Photoshop or whatever you may use.
There you go ^^
There you go ^^
uncle gena
How to make a screenshot easy way without any graphical editors
oh, thanks, dear uncle gena, it's a wonderfull software. Very easy.
difficult way...Reiziger wrote:Press Print Screen SysRq, a button which should be located on the right side of your keyboard.
There you go ^^
You say it's difficult to press only ONE button and after that paste it in paint?propolis wrote:difficult way...Reiziger wrote:Press Print Screen SysRq, a button which should be located on the right side of your keyboard.
There you go ^^
Do you think it's coincidence that propolis should ask a question like this, and then be impressed with the reply from his "uncle gena" (who has only ever made the one post) which advertises an $18.50 shareware program (downloaded a total of 21 times from Cnet) that is just an alternative to a single key press?Reiziger wrote:You say it's difficult to press only ONE button and after that paste it in paint?
Looks to me like very lame advertising.
stevethefiddle wrote:Do you think it's coincidence that propolis should ask a question like this, and then be impressed with the reply from his "uncle gena" (who has only ever made the one post) which advertises an $18.50 shareware program (downloaded a total of 21 times from Cnet) that is just an alternative to a single key press?Reiziger wrote:You say it's difficult to press only ONE button and after that paste it in paint?
what do you mean? I don't know nobody "uncle gena"....
yes, difficult. After it necessary to send via email etc..Reiziger wrote:You say it's difficult to press only ONE button and after that paste it in paint?propolis wrote:difficult way...Reiziger wrote:Press Print Screen SysRq, a button which should be located on the right side of your keyboard.
There you go ^^
Not difficult at all. Save the image in paint, attach the image to your email. The ol' one-two step.
If you want a more direct way, download SnagIt.
