Input source
Input source
Input source does not appear on my tool bar, so I can't record.
Re: Input source
This may be a Windows problem, but we never lose an opportunity to get people out of Audacity 1.2.
Audacity 1.2 is no longer support, patched, corrected or updated and hasn't been for a long time. Download and install Audacity 1.3.12 from here...
... and use that. You can install both versions safely, but you may only use one at a time. Audacity 1.3 Projects will not open in 1.2.
If you use Lame or FFMpeg, you need to get fresh versions from that same web site. Do Not use old software.
Administrator Note: I have locked this thread as the user appears to have taken your advice yesterday, Koz - as they have today posted the same query on the 1.3 Windows section of the forum - see: http://forum.audacityteam.org/viewtopic ... 16&t=54435
