I have a file I am opening, normalizing, and then exporting. The file properties disappear.
I am not sure why.
I am using XP. Audacity is version 1.2.6.
The file is a wav file. Before opening it, it has properties
In windows browser: right mouse-> properties-> summary
below are the properties:
After opening the file in Audacity, I selectBit rate =64Kbps
Audio Sample Size= 8 bit
Channels= 1(mono)
Audio Sample Rate 8 kHz
Audio Format CCITT u-Law
Edit -> preferences -> File Formats.
and have "uncompressed export format" set to "Other, WAV Microsoft, U-Law"
Which is all I want to do.. I want to normalize the sound volume and then export in this format.
I export the file. then in Browser, right mouse-> properties -> summary.
The display tells me "Summary properties are unavailable for the selected sources(s)."
Is this a bug in the Export feature for this file format??
TIA!
