The lame.buanzo web page is not working for me. Is there another place I can go to download this?
thanks
Need to download the LAME encoder
Re: Need to download the LAME encoder
The page seems to be down temporarily.
Try again later. It's not often down for long.
The version of Lame on the lame.buanzo web page is the version that you should use. Other versions are likely to cause problems.
waxcylinder
Gale just posted this in teh manual
Please note, the "LAME download page" links below are not currently working. Please download the version of LAME you require from heree http://www.gaclrecords.org.uk/audacity.html
Thank you both for the quick response.
