Commands Not Working
Didymos
Post by Didymos » Wed Feb 09, 2011 9:22 pm
When I click on a command, such as delete, nothing happens. The icon button for delete becomes depressed, but the data selected is not deleted. Using the key command has the same non-effect. The select command works, i.e. the selection becomes shaded, but it is as if the commands to delete, copy, paste, etc. have been disabled. I should add, maybe, this is all happening right from the point after I have installed the program. That is, it isn't as if it worked previously and stopped.
Thanks.
Re: Commands Not Working
Post by steve » Wed Feb 09, 2011 11:22 pm
Make sure that Audacity is "stopped". Most commands are unavailable when playing or paused.
Check that there are no other dialogues open (perhaps hidden behind the main Audacity window).
Didymos
Post by Didymos » Thu Feb 10, 2011 1:31 am
It worked. Thanks, Steve.
