Hi
I have 60 tracks that i would like to merge into one track.
Does anyone have an alternative to the toil of copying and pasting all the tracks.
Thanks in Advance.
Merge Multiple Tracks
Re: Merge Multiple Tracks
If they are all the same format you can join them end-to-end using SoX http://sox.sourceforge.net/
The command would be of the form:
For example if you had 3 files called "file1.wav" "file2.wav" "file3.wav" then you could join them together to form "new.wav" with the command:
Code: Select all
sox file-1 file-2 file-3 .... file-n output-fileCode: Select all
sox "file1.wav" "file2.wav" "file3.wav" "new.wav"9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
