Hello All--
I cannot seem to find a recent answer to this problem. If it has been resolved elsewhere, please forgive me in advance.
I have a PreSonus Firebox. I run Audacity 1.2.6 on a Windows 64 bit Vista system. I can record one input at a time no problem. However, I would like to record more than one input at a time on different tracks. The Firebox has a total of four inputs but I can only use one input at a time with Audacity. This has become frustrating as I would like to try multiple miking of my band. At a minimum, I would like to do this:
1. Place two microphones, through two different channels, for recording of drums, bass and guitar. The mics should hopefully ideally be two separate tracks. If I can get this to work, I may go so far as to try and record drums and bass on one track and guitar on another track. Again, however, I would want both to record at the same time.
2. Once the above is recorded, overlay vocals with a new track.
As it stands right now, we are having to record all of the instruments together and then overlay the vocals. Such is not ideal and I should be able to getter a better sound if I can increase my mic input up to at least two. Even better would be if I could use all four inputs through Audacity but that might be a bit too much to ask.
Can someone please help? I would really appreciate it. Thanks.
Matt
Presonus Firebox & Simultaneous Recording Of Multiple Inputs
Re: Presonus Firebox & Simultaneous Recording Of Multiple In
You will almost certainly want to upgrade to Audacity 1.3.12....
Audacity 1.2 is very old and no longer supported, patched or repaired. Audacity 1.3.12 has much better and more tools.
Multi-channel recording in Audacity can be an adventure. Typically, multi-channel devices are grouped in stereo pairs and Audacity will only recognize one pair at a time.
We beat this up in this thread:
http://forum.audacityteam.org/viewtopic ... 26&start=0
