--Windows XP
--Winamp as the default amp
I got the steam downloading properly and Winamp was playing it properly through my speakers,with proper left/right stereo separation.
However,when I started recording,only the left channel was recording.(Yes,it was set to stereo mix.)
The box in the lower left told me it was coming through at 16 bits, mono. I tried the drop down menu,but the stereo setting was in lighter type,and I could not get it out of mono.
Is this something the steamer set in because of copyright issues,or is there a way I can get a stereo recording?
Thank you.
((Edit.......Using Winamp is not carved in stone. What player works well for you?))
Mono/Stereo
Re: Mono/Stereo
********Please disregard.........I set it correctly,to two channel,in "Preferences".**************
