Just beginning my first serious editing/mastering project in Audacity and am getting about a 10% upward pitch shift. Device chain is as follows:
Original recording on Alesis Masterlink @ 24/44.1
S/PDIF out to TC Electroncs M2000 digital reverb
S/PDIF out to Alesis IO/2 USB interface into
Dell laptop running XP
FYI the M2000 in S/PDIF mode dithers to 16 bit, the IO/2 is a 24 bit unit.
The pitch shift also occurs running directly from the MasterLink into the IO/2.
Where is the change happening and what can I do to correct the problem??
Thanks in advance for any help.
Unwanted Pitch shift
Re: Unwanted Pitch shift
There are instances where Audacity had troubles dealing with 24-bit sound. Does it still do that if you try production at 16-bit or 32-bit floating?
It gives the same result no matter which bit rate I select within Audacity. It does not do it if I go analog in from the same source.
I am also having a pitch shift problem. In my case I am recording from an analog source and it is shifting down about a half step. I'm using version 1.2.4 . Any ideas?
1) Update Audacity - 1.2.4 is obsolete. (you can install both 1.2.6 and 1.3.x but you can only run one at a time. Projects that have been saved in Audacity 1.2 can be opened in 1.3, but projects saved in 1.3 can not be opened by 1.2)gaddis wrote:I am also having a pitch shift problem. In my case I am recording from an analog source and it is shifting down about a half step. I'm using version 1.2.4 . Any ideas?
2) Try changing the default sample rate (Edit menu > Preferences > Quality tab). If it is set to 44100, change it to 48000, if set at 48000 change it to 44100.
OK thanks. I will try that. My default rate was 44100. I also notice that the "recording device" in my AudioIO tab was set to Microsoft Sound Mapper -input. The recording tutorial says not to select this if you are running Windows XP (which I am). Could this have any effect?
I think that the tutorial says not to use Microsoft Sound Mapper input if you are recording from a USB device. If you are using a conventional (internal) sound card, then in most cases it is OK to use the Microsoft Sound Mapper.gaddis wrote:I also notice that the "recording device" in my AudioIO tab was set to Microsoft Sound Mapper -input. The recording tutorial says not to select this if you are running Windows XP (which I am).
