Hi
I loaded the program and I change the main thing to usb, but nothing goes in and nothing comes out. I can not record my voice. What should I do? Thank you.
How to record my voice
bvarzavand
Re: How to record my voice
You should provide more information.bvarzavand wrote:What should I do?
Exactly which version of Audacity (look in Help menu > About Audacity)?
Which version of Windows?
What are you trying to record from?
Is your recording device enabled in the Windows Control Panel?
What settings do you have for the recording device?
Any other relevant information
bvarzavand
Hi
my audacity is version is 1.2.6
I have windows Xp 2
I trying to record my voice with microphon that is provided by Xenyx music podcaststudio. All comes to one package.
Yes the driver is enabled in control pannel.
the setting I changed to "usb audio divice Codec"
That is all I have. Thank you.
I have windows Xp 2
Microphone plugged into the Xenyx mixer channel number 1 with XLR lead?
Does the microphone require "phantom power"? If so, do you have phantom power switched on?
Do you have a signal on the mixer's level meter when you speak into the microphone? (If it's a green>amber>red LED meter it should register up to the top of the green section but not light the red).
Which output of the mixer do you have connected to the USB interface?
Does the USB interface have a headphone socket? If it does, can you hear the microphone from the USB interface headphone socket?
