plugins greyed out in effect menu
rapattack1
I downloaded and put the effects in the audacity plugins folder but they are greyed out in audacity. I also installed the LADSPA plugins. Can't see anything new to work with when I reopened audacity. Also can someone tell me if any of the programs has a separate volume control of each track. So I can adjust the volume of each track at any point but especially before I render? I have had audacity installed before but I had some kind of hardware issue I think(different computer) and I have it installed on Ubuntustudio but no one has helped me far enough with damn Jack so I am forced to use crappy old windoze.
Re: plugins greyed out in effect menu
<<<I downloaded and put the effects in the audacity plugins folder but they are greyed out in audacity.>>>
Just to cover the bases, you did select some audio on the timeline first, right?
rapattack1
Oops that never occured to me. Thanks that is exactly what i was supposed to do. *embarrassed*
