We've deployed Audacity 1.2.6 on our school labs and I was wondering is there a way to define a default set of preferences for users? Right now, every time a user logs in for the first time, they must setup Audacity's language, inputs, and mp3 export library settings. It's very time consuming in a lab environment to get everyone setup with the same defaults. And then when a new set of students come in, it repeats all over again.
It would be nice if there was a way to set a global config that provides defaults for everyone out the gate, and then they could still customize their settings more afterwards. But I cannot seem to find this type of functionality. It looks like 1.3.x series can probably do this, sort-of with the "portable app" folder configuration file. But I'm wondering if there is a way to provide this for the 1.2.6 stable release?
Thank you.
Custom Default Preferences?
waxcylinder
Re: Custom Default Preferences?
1.2.x uses the Windows Registry to store it's preferences - so it may be difficult.
In 1.3.x (and presumably therefore in the upcoming 1.4) the is an audacity.cfg configuration file stored in C:Documents and Settings<user_name>Application DataAudacity - so you may be able to copy this to all created accounts when you transion to 1.3 or 1.4
Yes that will work, and is probably the best way to do it.waxcylinder wrote:In 1.3.x (and presumably therefore in the upcoming 1.4) the is an audacity.cfg configuration file stored in C:Documents and Settings<user_name>Application DataAudacity - so you may be able to copy this to all created accounts
An alternative way is to create a directory called "Portable Settings" in the same directory as the Audacity executable. "audacity.cfg" will be stored there instead of in Settings<user_name>Application DataAudacity
The disadvantage of this second method is that if one person messes up the config file, it is messed up for all users (though keeping a backup copy of the correct config file would make it very quick and easy to restore).
(Note: this 2nd method is also for Audacity 1.3 and later)
