Playing recorded CD's
David Moore
I have successfully recorded some WAV files from an LP to my computer. These files can be played on my computer. However, when I try and play them on a 'stand alone' CD player nothing happens. The recorded tracks do not even seem to be recognised. Can anyone help?
waxcylinder
Re: Playing recorded CD's
It is possible that you are burning your CD as a data CD - what you need to do is to burn a Music CD or Audio CD.
There should be a setting in your CD burning software to switch bewteen data burning and music/audio burning.
BTW: the WAVS should be exported at 44.1kHz 16-bit PCM stereo (the REd Book standard for CDs)
