When I try to install Audacity on my company laptop, I get the message:
Error creating registry key:
HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionUninstallAudacity_is1
RegCreateKeyEx failed; code 5.
Access is denied.
This looks to me like the installer tries to add an icon in ADD/REMOVE PROGRAMS in control panel. Can anyone help me determine a workaround for this?
Is there a way to go in and change the 1 value to 0?
install problem; work around?
silverhorn
Re: install problem; work around?
You probably don't have the necessary Administrative privileges to install a program that makes registry entries.
You could try installing Audacity 1.3.x as this saves preferences in a file rather than the registry. If that fails you will need to ask your computer administrator to install it for you.
bradpitt786
You could try installing Audacity 1.3.x as this saves preferences in a file rather than the registry. If that fails you will need to ask your computer administrator to install it for you. I think that you may probably don't have the necessary Administrative privileges to install a program that makes registry entries.
brad
brad
