Accessing Help File
Accessing Help File
I have downloaded the HELP file. Where do I need to place it to be able to locate it from within Audacity? Thanks for the help!
Re: Accessing Help File
In the current versions of Audacity, this does not work. Just put them in a folder anywhere and make a link somewhere convenient. Once you have been using Audacity for a couple of weeks you probably won't need the help files anyway.
Hopefully version 1.4 (when it is released) will have the help files available from within the help menu.
