Is it possible with Audacity to record a new track of narration while listening to the already-established file of music it will run with?
I am using music (for choreography) which is very difficult to count. I need to record my voice counting this music while it plays. (I plan to burn CDs for the dancers to study.)
Right now this doesn't seem possible to me as I can't figure out how to hear the music in playback as I record my voice.
Claire
Recording Over Existing File
Re: Recording Over Existing File
Yes you can, although it can be a little more complicated if you are using a USB microphone.
I'll assume that you are using a conventional microphone.
In Audacity, go to "Edit > Preferences > Audio I/O" and select "play other tracks while recording new one". (do not select "software playthrough" as this will cause weird echo effects).
Steve,
Thank you so much. That worked beautifully.
Claire
Claire
