Effects?
slark
Re: Effects?
Post by slark » Thu Dec 23, 2010 1:47 am
I upgraded to 1.3.12 after I discovered that I could not record twice on the same track in the old version.
What I think I'll do, as you suggested, I'll keep a dry version of every track muted, and then delete and replace the wet version if I have to. That should work.
slark
Re: Effects?
Post by slark » Sat Dec 25, 2010 2:48 am
You know, I'm using 1.3, and I've just discovered that when I apply, say, compressor, to a track and then copy it and paste it into a new track, it emerges without any compression, in its 'dry' form. Or am I missing something?
Re: Effects?
Post by steve » Sun Dec 26, 2010 10:38 am
I think you'll find that it doesn't.
