Nyquest "Notch filter" plugin
Mull
Post by Mull » Mon Jun 09, 2008 9:04 pm
There may be a problem with the "notch filter" Nyquest plugin zip file. After downloading to Windows XP Pro, attempts to open result in this error message: "The compressed (zipped) folder is invalid or corrupted."
Is there a way around this?
Re: Nyquest "Notch filter" plugin
Post by steve » Mon Jun 09, 2008 9:21 pm
Probably just an error downloading it. Try downloading it again. You then need to unzip it into your Audacity plug-ins folder.
Where are you downloading from?
