How can I combine audio files together (2 or more) so that when I save it, it plays as one?
Thanks
How to combine audio files
spawnxshadowx
SigmaRemix
Re: How to combine audio files
By save, do you mean export? I think muting all tracks but the ones you want and then exporting the file would do the trick...
Another way to interpret the question:
Load the second song and Edit > Select > All, Edit > Copy. Then load the first song and place the cursor at the end [End]. Edit > Paste.
Then export as WAV or MP3 as you wish. Both songs will play, first 1 and then 2.
