Cant select 'stereo mix' in the right with EMU 0202
uhslez
Re: Cant select 'stereo mix' in the right with EMU 0202
Post by uhslez » Fri Dec 24, 2010 1:22 pm
When host is MME
Playback device options are:
Microsoft Sound Mapper - Output
EMU 0202 USB
Realtek HD Audio Output
Recording Device options are:
Microsoft Sound Mapper - Input
EMU 0202 USB
Realtek HD Audio Input
When host is Windows DirectSound
Primary Sound Driver
EMU 0202 USB
Recording device options are:
Primary Sound Capture Driver
EMU 0202 USB
Happy Christmas!
Post by steve » Fri Dec 24, 2010 2:36 pm
No mention of "Stereo Mix" in there.
uhslez wrote:I tried to change the recording device in both, control panel and audacity preferences, but it still wouldnt record - the stereo mix option comes available tho.
Where are you seeing the "stereo mix" option?
uhslez
Post by uhslez » Fri Dec 24, 2010 7:59 pm
in the right, when I have selected realtek as a recording device, but it still doesnt record.
Post by steve » Fri Dec 24, 2010 9:29 pm
"In the right" ?
Could you post a screenshot.
uhslez
Post by uhslez » Fri Dec 24, 2010 11:28 pm
http://www11.speedyshare.com/files/2588 ... dacity.JPG
with these settings it comes available, but it isnt recording.
Post by steve » Sun Dec 26, 2010 11:14 am
Thanks, that screenshot shows exactly the right thing :)
The "Recording" device (in Preferences) is set to "RealTek" which is the computer's internal sound card.
"Stereo Mix" in the "Device Toolbar" shows the specific input that is selected for the "Device" that is selected in Preferences. In this case you have selected the "Stereo Mix" input of the "ReakTek" sound card. This will record everything that is playing through the RealTek sound card.
If you change the Recording Device in Preferences to USB then the recording device will be the E-MU 0202, but I expect that "Stereo Mix" will no longer be available in the Device Toolbar because XP does not (usually/ever?) support Stereo Mix for USB devices.
The ideal solution would be to make a little switch box so that you can switch between "loopback" and ordinary input to the 0202. If you know anyone that makes electronic projects I can post a wiring diagram for you (it's quite a simple project for anyone that can use a soldering iron).
