Hey guys
Well, the problem I have is as follows:
When I start recording my wav file, everything's okay no problem. If i stop my recording and wish to continue recording from where I left off, that's where the problem occurs.
After stopping and recording, even though the sound gets recorded, the waveform doesn't appear, the cursor just keeps moving. Subsequently, I am unable to perform any edit based operations (Cut, Delete etc) on the second part of the recording.
Can someone tell me what I'm doing wrong?
I'm using version 1.2.6 and my OS is Windows XP Service Pack 2.
Thanks in advance
Problem with editing
gornomatic
Re: Problem with editing
What are you recording from? Line in> Mic in? USB turntable (shudder)
How do you know that it has been recorded? Does it play back OK?gornomatic wrote:ven though the sound gets recorded, the waveform doesn't appear
