Tool bar ????
bjs
Tool bar ????
Post by bjs » Wed May 28, 2008 6:31 pm
1.2.6 Just loaded up....... worked fine, recorded and everything. Third time I went into it the tool bar now displays only ????? instead of File, Edit etc......
Any remedy apart from reload?
Re: Tool bar ????
Post by steve » Wed May 28, 2008 8:06 pm
It sounds like you have accidentally changed the language settings.
Find the instructions for your version of Audacity on this page: http://www.audacityteam.org/wiki/index. ... t_language
bjs
Re: Tool bar ????
Post by bjs » Thu May 29, 2008 9:57 am
SOLVED!
Thank you! Excellent......
Great bit of forethought there on the instructions about 'if all you have is ??? then go to the 2nd menu, bottom selection, 6th along' etc etc.
Somehow or other it went to Arabic. How? Do not know.
However, being Arabic it came back with ???????
Thanks again!
From what I've used so far it's a very good piece of software.
Cheers
BJS
